Fuel pump relay?
HARPER051
where do I locate the fuel relay pump on my car?
Sep 9, 2008 at 6:28 AM
  • 55,770 POSTS
Here is a guide to help you test the relay so when you find it below.
Check out the diagrams (Below)
Cheers, Ken
Feb 19, 2018 at 6:20 AM
NICK KOOL
Where can i find the fuel pump relay? car wont start i just put new fuel pump and it was running ok but now it wont start, i dont hear any noise from the pump when key is on, can you help?
Jan 6, 2020 at 7:10 AM (Merged)
  • 75,988 POSTS
Here is a guide to help you test the relay with the fuel pump relay location below.
PATLEE
Where is it located? I'm installing a fuel pump and need to check the relay...
  • 55,770 POSTS
Installing a new fuel pump relay is not to bad of a job. You can try direct power to the fuel pump to see if the pump works. See below
https://images.2carpros.com/forum/automotive_pictures/12900_fuel_pump_relay_27.jpg
Here is the fuel pump location for a newer model https://www.2carpros.com/questions/cadillac-deville-2000-cadillac-deville-fuel-pump-relay Please let us know happens so it will help others. Best, Ken
RICH001
My Cadillac runs perfect on all short trips, but after a longer trip (60 min. or more), it will not start and is not getting fuel. I replaced the filter, and am now trying to locate the fuel relay switch. I have a manual that says it is beside the fuse box, which it isn`t. I went to the GM dealer, and they said it was on the firewall, which it isn`t.. so I have a new relay and nowhere to put it..
MERLIN2021
  • 17,250 POSTS
Check engine compartment relay block near the washer fluid reservoir...
BUZZSAW
  • 1,198 POSTS
[quote:fc99173667="Rich001"]Electrical problem
1986 Cadillac Deville V8 Front Wheel Drive Automatic 140000 miles
My Cadillac runs perfect on all short trips, but after a longer trip (60 min. or more), it will not start and is not getting fuel. I replaced the filter, and am now trying to locate the fuel relay switch. I have a manual that says it is beside the fuse box, which it isn`t. I went to the GM dealer, and they said it was on the firewall, which it isn`t.. so I have a new relay and nowhere to put it..[/quote:fc99173667]
its on the firewall, under a black cover made of plastic,
there are 3 of them there, and some fuses, I dought this is your prob, is there a ck engine lite on? need codes, push off and warmer on heater controls, and they display on heater assy, write them down, with out looking at it I would say your prob is in the distributor, cam sensor or pick up coil
RICH001
Thanks for your advice.. I tried the codes the last time my car wouldn`t start.. I got a BCM code 32 and 48.. The code 32 is my MAP sensor circuit open. Should I be replacing it instaed of the relay?. I found the relay behind the glove compartment..
WOODYCOFF
engine turns over but no fuel coming from injectors in throttle body
FIXITMR
  • 9,989 POSTS
Did you look for it underhood in a fusebox or on a bracket? here's a pic from book. #3 is the pump relay.
FIXITMR
  • 9,989 POSTS
looks to be under dash pass side interior.
POPROCKS6301
  • 13 POSTS
I need to find out what the fuel pump relay looks like. i found all of the relays under the dashboard and i don't know how to tell which ones which. i have got a 4.1 L V8 Cadillac Coupe Deville 1983 model. its got digital fuel injection if that makes a difference. thanks for your time.
it is on the rely center under the dash as you were describing.
why are you looking for this?? what is the issue??
POPROCKS6301
  • 13 POSTS
i am looking for the fuel pump relay because there is a problem with fuel getting to the engine. the gas tank is not pumping gas at all. i am hoping that it is not the fuel pump. but i am trying to go with the cheapest things first. the reason i need to find the fuel pump relay is because i need to check it and see if it is plugged in or if there even is one.
POPROCKS6301
  • 13 POSTS
i am trying to find out and see if there is something electrical going on that could be stopping the car fuel pump from pumping
  • 110,251 POSTS
Did you check under the hood in the relay block?
POPROCKS6301
  • 13 POSTS
could not find a relay block under the hood.
POPROCKS6301
  • 13 POSTS
on the car the relay block is on the fuzebox
the relay block is under the dash
