I closed the driver side front door and window fell into the door. Is it just off track or what. All other windows work fine.
Jul 12, 2008 at 3:15 PM
2CARPRO JACK
✓Experienced Mechanic
usually if they are off the rtack they will jam and not work properly, sounds like you may have a problem with the regulator or motor.Need to remove th edoor panel to physically look and see what broke
