[quote:776518a7f0="taylor_9825"]I took the car to autozone and they said there was nothing wrong. It wasn't giving a code. That went off after a few days. Now I have a check coolant level showing, after I had the thermostat changed. But the car isn't running hot, but the heater is blowing cool air.[/quote:776518a7f0]
if you scaned your codes the way I asked you to do through your heater/AC controls you will get the codes, you dont need autozone, they can only scan PCM codes I need the Body codes, and it is vary hard to get an air pocket in this system, if you have low coolant you still have a leak somewhere
Jun 11, 2008 at 5:43 AM
