2000 Cadillac Deville cylinder 2 misfire
134,000 MILES • V8 • FWD • AUTOMATIC
CNS38
need more info on a code p0302 misfire cylinder num 2 changed plugs and wires still runs bad
Mar 3, 2008 at 1:56 PM
BUZZSAW
  • 1,198 POSTS
[quote:d25c208ef3="cns38"]Engine Mechanical problem
2000 Cadillac Deville V8 Front Wheel Drive Automatic 134000 miles
need more info on a code p0302 misfire cylinder num 2 changed plugs and wires still runs bad[/quote:d25c208ef3]
take an ohm reading on the injector, and a couple others
that engine has coil packs I think? in the top of the valve cover right? if injector is ok replace the coil packs
Mar 5, 2008 at 12:33 AM
