2000 Cadillac Deville ac off
2000 CADILLAC DEVILLE
132,000 MILES • V8 • FWD • AUTOMATIC
JIMBOBAD
I had my valve gasket fixed. The ac was cranking cold when I brought in, when I got it back the ac said off on the dash. I brought it back the mechanic said it was the high pressure switch. I change it and still no ac. I also changed the ac swicth and nothing. I ran a wire from the compressor to a power source and the clucth engaged,just to make sure it worked. I dont know. Its hot in Florida, any suggestions.
Jan 11, 2008 at 1:14 AM
BUZZSAW
  • 1,198 POSTS
[quote:229b14e96f="jimbobad"]Air Conditioning problem
2000 Cadillac Deville V8 Front Wheel Drive Automatic 132000 miles
I had my valve gasket fixed. The ac was cranking cold when I brought in, when I got it back the ac said off on the dash. I brought it back the mechanic said it was the high pressure switch. I change it and still no ac. I also changed the ac swicth and nothing. I ran a wire from the compressor to a power source and the clucth engaged,just to make sure it worked. I dont know. Its hot in Florida, any suggestions.[/quote:229b14e96f]
you have to erase the codes to make it work, to scan for codes press off and warmer on heater controls, it will go through diagnostics, write the codes down
Jan 11, 2008 at 8:46 AM
