2000 Cadillac Deville
JDEEM101
  • 2000 CADILLAC DEVILLE
  • V8
  • FWD
  • 80,000 MILES
How do you disassemble the rear passenger door panel to do work on the windows?
Saturday, August 30th, 2008 AT 6:52 PM
KHLOW2008
  • 41,814 POSTS
Hi jdeem101,
Thank you for the donation.
DOOR CONTROL MODULE
Removal & Installation
Run window to full down position. With manual lock knob in unlock position, use flat-blade tool to disengage locking clip in service notch at front of knob.
With door inside door handle in open position, use flat-blade tool in lower front corner to remove bezel.
Remove screw retaining inside door handle. Use Clip Zip Tool (J36796) to release 8 retainers holding trim panel to door.
Push panel upward to release trim panel from door, disconnect electrical connector and remove trim panel.
To install, reverse removal procedure.
Page 1 of 1 POWER DOOR LOCKS -2000 Cadillac DeVille
Sunday, August 31st, 2008 AT 12:22 AM
