ealer does not offer a gasket for the oil pan
CHEVYSHOP
The dealer does not offer a gasket for the oil pan. Should I use RTV or buy a aftermarket gasket?
Jun 4, 2008 at 3:49 AM
BUZZSAW
  • 1,198 POSTS
[quote:ae7a3ea31f="chefshop"]2000 Cadillac Deville V8
The dealer does not offer a gasket for the oil pan. Should I use RTV or buy a aftermarket gasket?[/quote:ae7a3ea31f]
there are 2 oil pans that need sealed, there is a special sealer for the pans, RTV wont work, the sealer is red, it hardens up under pressure when the bolts are tightened
to do the oil pans you have to remove the transmission and suspend the motor in the car
May 8, 2021 at 4:21 AM
