STALLS WHILE DRIVING?
134,000 MILES • V8 • 2WD • AUTOMATIC
FLEETWOOD85
caddy 99 deville the fuel pump replaced,new spark plugs,new wires, injectors were cleaned, new air cleaner. car shuts off while driving .it will start right back up and go .get to the next light and the same thing ....... what next??????.
Apr 1, 2008 at 8:55 AM
BUZZSAW
  • 1,198 POSTS
[quote:06b7c7b4a5="fleetwood85"]Engine Performance problem
1999 Cadillac Deville V8 Two Wheel Drive Automatic 134000 miles
CADDY 99 DEVILLE THE FUEL PUMP REPLACED,NEW SPARK PLUGS,NEW WIRES, INJECTORS WERE CLEANED, NEW AIR CLEANER. CAR SHUTS OFF WHILE DRIVING .IT WILL START RIGHT BACK UP AND GO .GET TO THE NEXT LIGHT AND THE SAME THING ....... WHAT NEXT??????.[/quote:06b7c7b4a5]
any ck engine light?
no, replace the crank sensors. both of them, and a relearn will have to be preformed at the dealer.
yes, still would say crank sensors
pull the codes, off and warmer on the heater controls at the same time, with key in the on position. ( if no warmer button use the mode button down)
Apr 3, 2008 at 7:08 PM
MIKEYSTAATS
I swear to God this exact thing happened to me. I replaced everything that was mentioned, even EGR and cleaned the throttle body. And no one will ever guess what fixed it. A new key! I always used the regular gold key that came with the 1999 Deville, it only had 39,000 miles on it, but the key was starting to look all worn so I decided to use the spare keys. It hasn’t stalled since and it’s been working flawlessly for like 3 months. Which is a huge improvement compared to stalling out at every light. I’m guessing something went weird inside of the old set. But knock on wood. I think that’s your issue.
May 5, 2023 at 3:21 AM
  • 55,748 POSTS
Excellent addition to this thread! Please feel free to use 2CarPros anytime!
May 5, 2023 at 3:45 AM
