1999 Cadillac Deville no ground to fuell inyectors
132,456 MILES • V8 • FWD • AUTOMATIC
SONORENSE
car starts for a few seconds and dies . i have check all sistems gas,spark comp. there is power to the inyectors but no ground, ignition module or pcm could be the problem
Jan 19, 2010 at 3:44 AM
FACTORYJACK
  • 4,159 POSTS
The PCM controls the ground. If you could check the codes, it is possible that the theft system has disabled fuel for some reason. Press off and warmer on your climate panel, after the segment check, it will display codes. Record and report them.
Jan 19, 2010 at 2:23 PM
