how do I remove the whole headlight assembly can't see some of the bolts.
Jun 14, 2009 at 4:13 AM
FACTORYJACK
✓Experienced Mechanic
There is a lower bolt on the inside of the housing, one bolt on top of the housing, and two nuts visible after removing the cornering lamp screw and assembly.
Jun 14, 2009 at 4:30 AM
7545GI
MEMBER
Is there a diagram available to show where the fasteners are?
Jun 15, 2009 at 3:32 AM
FACTORYJACK
I don't have a means(or know how) to send a diagram. Which fasteners have you got, which ones are you looking for? Have you removed the cornering lamp lens.
Jun 15, 2009 at 2:18 PM
7545GI
MEMBER
Where are the screws that hold the corner light to the main headlight assembly?
Jun 16, 2009 at 2:26 AM
FACTORYJACK
There is only one screw for the cornering lamp, it comes down from the top in the cavity where it and the headlight meet. I believe it is an e-torx fastener requiring a special socket. Some sizes will fall to a 6-point socket though, usually SAE, with a try if that is all you have.
Jun 16, 2009 at 4:04 PM
7545GI
MEMBER
Yep I finally found the cornering lamp fastening screw and changed my headlamp assembly, thanks for the help.
