1999 Cadillac Deville hard starting
68,234 MILES • V8 • FWD • AUTOMATIC
CHEV104275
when the car is dead cold it starts fine after it warms up it has a real hard time starting it takes a few cranks or one real long one ive replaced the fuel filter and plugs what should i do next ?
Jan 11, 2008 at 1:03 AM
BUZZSAW
  • 1,198 POSTS
[quote:6fd038b4ce="chev104275"]Engine problem
1999 Cadillac Deville V8 Front Wheel Drive Automatic 68234 miles
when the car is dead cold it starts fine after it warms up it has a real hard time starting it takes a few cranks or one real long one ive replaced the fuel filter and plugs what should i do next ?[/quote:6fd038b4ce]
what kinda plugs? you need to scan the pcm for codes, push off and warmer on heater controls and it will go into diagnostics, write down the codes and give them to me, plugs are replaced at 100k miles
Jan 11, 2008 at 8:49 AM
CHEV104275
[quote:6e80211841="Buzzsaw"][quote:6e80211841="chev104275"]Engine problem
when the car is dead cold it starts fine after it warms up it has a real hard time starting it takes a few cranks or one real long one ive replaced the fuel filter and plugs what should i do next ?[/quote:6e80211841]
what kinda plugs? you need to scan the pcm for codes, push off and warmer on heater controls and it will go into diagnostics, write down the codes and give them to me, plugs are replaced at 100k miles[/quote:6e80211841]i used autolite plugs i only replaced them to try and repair the concern there are no pcm codes
Jan 12, 2008 at 12:14 AM
BUZZSAW
  • 1,198 POSTS
[quote:5d09db6d6e="chev104275"][quote:5d09db6d6e="Buzzsaw"][quote:5d09db6d6e="chev104275"]Engine problem
when the car is dead cold it starts fine after it warms up it has a real hard time starting it takes a few cranks or one real long one ive replaced the fuel filter and plugs what should i do next ?[/quote:5d09db6d6e]
what kinda plugs? you need to scan the pcm for codes, push off and warmer on heater controls and it will go into diagnostics, write down the codes and give them to me, plugs are replaced at 100k miles[/quote:5d09db6d6e]i used autolite plugs i only replaced them to try and repair the concern there are no pcm codes[/quote:5d09db6d6e]
a couple questions? where do you live? (roundabout)
a cheap part to try is a fuel PSI regulator, get it at the dealer 25-30 bucks, its in the fuel rail, something else to try is crank sensors, both of them, a crank sensor relearn will have to be done after, at the dealer,( a tech 2 diagnostic reader is needed to do it ) I would do this first!!!!
Jan 13, 2008 at 4:04 AM
