1999 Cadillac Deville fuel pressure
V65MAGNAMAN
Engine Performance problem
1999 Cadillac Deville V8 Front Wheel Drive Automatic
car was runing fine backed out went forward started missing lost almost all power like out of gas fuel guage stay on full put gas in bout 2 gal wondering if u haft to bleed rail and whear is it
Dec 18, 2009 at 6:37 PM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Dec 18, 2009 at 6:45 PM
