1999 Cadillac Deville front struts
65,000 MILES • V8 • FWD • AUTOMATIC
BIG BRUCE
method of replacing shock absorbers or struts on front
Oct 15, 2009 at 8:22 AM
FACTORYJACK
  • 4,159 POSTS
Three nuts on top of each one under the hood. Two large bolts at the spindle. Removal of the lower two bolts may cause a camber change resulting in need for alignment. You will need a spring compressor to unload the forces for disassembly. Remove the strut shaft nut, transfer insulators, boots, bumpers, and reassemble.
Oct 15, 2009 at 3:15 PM
