1999 Cadillac Deville erase code
200,007 MILES • V8 • FWD • AUTOMATIC
JP_TAMMY
on my driver information center or d.i.c i have a few message like check your cooland level or service stearing systeme, or idle controle systeme, everything got fix or fill up so now how do i get rid of those message???
Jun 20, 2010 at 12:57 PM
FACTORYJACK
  • 4,159 POSTS
If everything got fixed, those messages would go away on there own. The coolant level may be a stuck sensor, the steering/stability system fault, idle fault may be emissions related.
Jun 23, 2010 at 4:02 PM
JP_TAMMY
the coolan is full, i just got a new steering rack,pinion power steering pump and cooler plus the high pressure hose replace and i still have those 3 message coming on check coolant level,service steering systeme,ans service idle controle???if i unplug my battery would that erase them???or if i get the car to do its own diagnostic would it help you if i give you the number of those code 3 letter and some numbers????
Jun 30, 2010 at 1:11 PM
FACTORYJACK
  • 4,159 POSTS
Like I say, if your coolant is full, and you get a low coolant message, it could have a bad sensor that is part of the reservoir. Your P.S. gear, pump, and such have little to no relevance on the service steering message UNLESS, the magnasteer actuator(on the gear) is electrically disconnected, or routed improperly to where it chaffed or burned through on the EGR pipe. Another possibility could be a disconnected or faulty P.S. pressure switch that is on the pressure hose, this might cause the idle message as well, since the ECM uses it to adjust idle speed in response to steering load. If you could gather all the codes and report them back, I should be able to provide some further analysis.
Jun 30, 2010 at 4:54 PM
