1999 Cadillac Deville display says "service AC system&
124,000 MILES • V8 • 2WD • AUTOMATIC
BRJR14
The display says "service AC system. I checked the owners manual and it said " sensors that control the AC/heat system needs service. I tried to put freon in the compressor and i cannot keep the auto on so the Ac works, its goes back "econ", therefore i cant get the freon to take. What sensors are needing to be replaced and where are they located.
Mar 25, 2010 at 10:41 AM
FACTORYJACK
  • 4,159 POSTS
If it is seeing low refrigerant, it will default to econ for compressor protection. To do this correctly, You should have the system diagnosed/recovered to determine the state of charge. It could be one of two things, it is actually low on refrigerant or, it has a faulty pressure/temp sensor falsely reporting a low refrigerant charge. The same low refrigerant code could set in either case.
Mar 25, 2010 at 5:14 PM
