Dash Board Lights
117,772 MILES • V8 • 2WD • AUTOMATIC
WILLIAM2610
While driving my dash board suddenly went out. Due to the dash board going out; I can't see the speed odometer, fuel amount, etc. What causes this issue?
Aug 10, 2010 at 2:42 PM
More than likely this is just the illumination circuit for this cluster. So, we need to start by checking the power on the fuse for the cluster.
I am attaching the wiring diagram that helps with this.
However, here are a couple of guides that will help with this:
Please see the info below on the wiring diagram and the fuse panel info.
Let us know what you find, and we can go from there. Thanks
Feb 6, 2022 at 9:19 PM
