Blower will not shut off when engine is shut off, but can cut off air condition
Tuesday, July 6th, 2010 AT 10:04 AM
BLUELIGHTNIN6
MECHANIC
Hello and thanks for donating
The most likely culprit would be a stuck / faulty blower motor relay. Test the relay, if it is OK then the blower motor resistor may be the issue and will need tested.
