1999 Cadillac Deville Bleeding procedure
VAUGHN_123
Engine Cooling problem
1999 Cadillac Deville V8 Front Wheel Drive Automatic 100k miles
Is there any bleeding procedure on the NorthStar engine, because Im having overheating issues with it and have replaced the thermostat, and there is "flow" in the system
Jun 10, 2010 at 9:29 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you can try burping the cooling system, remove radiator cap than start engine and let run until warm. if you see air bubbles coming to top then there was air in it. may be something different though like a blockage in system, faulty water pump or bad cooling fans
Jun 10, 2010 at 10:32 AM
