Engine Cooling problem
1999 Cadillac Deville V8 Front Wheel Drive Automatic
If your anti-freeze is disappearing, you are using the wrong type of anti-freeze. Look at your radiator and follow the instructions. Once you put in the proper anti-freeze, your engine will stop burning oil and overheating. THE ANTIFREEZE YOU USE SHOULD NOT CONTAIN SILICATE.
Aug 10, 2010 at 9:38 AM
