1999 Cadillac Deville abs and traction control
127,000 MILES • V8 • FWD • AUTOMATIC
ROSLYN AARON
often when I put on breaks, my break pushes back and I hear a click sound. My breaks seem ok. In the past, this happened only occassionally when it was wet/slick outside. Now, even on a dry day it comes on often. It goes off when the car is turned off and when it started back up, eventually it will come on again. I've been reading the comments and I'm thinking it may be the wheel sensors or maybe the lines need to be bled. I just had my rear breaks and drums changed.
May 18, 2008 at 9:26 AM
BUZZSAW
  • 1,198 POSTS
[quote:0af3070436="Roslyn Aaron"]Brakes problem
1999 Cadillac Deville V8 Front Wheel Drive Automatic 127000 miles
often when I put on breaks, my break pushes back and I hear a click sound. My breaks seem ok. In the past, this happened only occassionally when it was wet/slick outside. Now, even on a dry day it comes on often. It goes off when the car is turned off and when it started back up, eventually it will come on again. I've been reading the comments and I'm thinking it may be the wheel sensors or maybe the lines need to be bled. I just had my rear breaks and drums changed.[/quote:0af3070436]
1 thing you have 4 wheel disc no drums, you need to pull the codes, off and warmer on the heater controls at the same time with your key in the on position, this will put it in diag mode
May 21, 2008 at 11:09 AM
