1999 Cadillac Deville
106,000 MILES • V8 • AWD • AUTOMATIC
JBELL6156
I have a 99 Cadillac Deville with 106,000 miles and my Service Stability light/Traction Control is on. What cause this? Is it expensive to repair? Does this mean I have no control over this vehicle in bad wheather?Does the sensor or module cause this problem? How much do the sensor and module cost?
Nov 7, 2009 at 11:47 AM
FACTORYJACK
  • 4,159 POSTS
It could be one of many possibilities, and usually the system disables when a fault is detected. Wheel speed sensor, steering position sensor, Brake/Traction module, Wiring, etc... There should be fault codes associated with this, and that would direct you in a repair process, and a closer estimate of cost. If you press off and warmer on your climate panel, after a segment check, it should display codes. ABS codes(CXXXX) are what you are after. If you can get me a code(s), I might be able to further assist you.
Nov 8, 2009 at 4:46 AM
