1998 Cadillac Deville water pump
DAVE5419
Engine Cooling problem
1998 Cadillac Deville V8 Front Wheel Drive Automatic
where is it located on the nothstar engine. how to replace.
Mar 13, 2010 at 6:48 AM
BMRFIXIT
  • 19,053 POSTS
Water Pump Remover/Installer (J-38816) is required to turn pump assembly. Drain cooling system. Move engine torque strut for access. Remove air cleaner. Remove water pump belt cover (4 bolts). Remove water pump drive belt, by-pass hose, lower hose and pump cover. Using Remover/Installer (J-38816), rotate water pump assembly clockwise, and remove from vehicle
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_677.jpg
Mar 13, 2010 at 6:54 AM
