1998 Cadillac Deville Water pump
GAL0050
  • 1998 CADILLAC DEVILLE
  • V8
  • FWD
  • 150 MILES
Water pump change, best way to change without messing with components around it.
Tuesday, June 8th, 2010 AT 4:22 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating.
A few things must be moved to replace the water pump, you will also need special service tool J-38816 (water pump remover/installer) for this repair. The engine torque strut must be moved. Also have to remove the air cleaner and water pump belt cover (4 bolts). Then you can access the water pump drive belt and hoses.
Tuesday, June 8th, 2010 AT 4:27 PM
