1998 Cadillac Deville water leaking
160,250 MILES • V8 • FWD • AUTOMATIC
CYAIRAMC
i have water leaking inside my car when i run the ac in my car. we think that the evaporator box's drain hose is clogged. but we cant find it. where can we find the hose?
Jun 24, 2010 at 11:02 AM
FACTORYJACK
  • 4,159 POSTS
There is no hose for a 98, the evaporator is serviced outside the vehicle. It does have a drain. If you look at where the lines connect to the evaporator, and follow the seam in the rubber barrier, it is at the bottom. Perhaps looking up may be easier, if I remember correctly, you can see it from below.
Jun 25, 2010 at 2:57 PM
