1998 Cadillac Deville warning light
90,000 MILES • V8 • FWD • AUTOMATIC
RICKGSAVOIE
I've been getting a "CHECK STABILITY" warning. I don't what this means. I wonder if has anything to do with the driver side power window not working. Thanks for your help---Rick
Sep 29, 2009 at 10:09 AM
FACTORYJACK
  • 4,159 POSTS
It relates to your ABS/Traction control system. This fault will set a code in the system to direct a person in repairs. There are several possibilities in what could be causing it. A code would simplify. To obtain your codes, press 'Off' and 'Warmer' on your climate panel, and codes will display after the segments check. ABS codes are what your after, post the results.
Sep 29, 2009 at 3:32 PM
