1998 Cadillac Deville right rear rear wheel speed sensor
1998 CADILLAC DEVILLE
86,000 MILES • V8 • FWD • AUTOMATIC
GLENN2000
I have the tcs code that says the right rear wheel speed sensor is not reading so it is causing my abs and traction control lights to stay on. I replaced the rear wheel bearing hub whiech has the speed sensor on it but still have the same problem what can I do to fix this problem I even installed anouther hub just in case I had a bad part but that was not it.
Dec 8, 2009 at 1:20 PM
FACTORYJACK
  • 4,159 POSTS
At this point, you will need to check the integrity of your circuits from the sensor connector to the EBTCM under the hood. Check of course, your terminals at the connector. They can be loose fit and not making contact. You almost need a male terminal that mates with the female terminal in the connector, and when engaging them, there should be some drag. If you hold the connector terminal side down, the male should not fall out of either terminal.
Dec 8, 2009 at 3:41 PM
