1998 Cadillac Deville head gaskets
144,545 MILES • V8 • FWD • AUTOMATIC
ED1214
do you have the specs on head gaskets,because i need to replace them
Sep 11, 2010 at 6:19 AM
FACTORYJACK
  • 4,159 POSTS
What specs are you after? If you are considering head gasket replacement, you need to consider also that most likely you have some head bolt threads that have pulled. That is most often why the head gaskets start leaking. There is a special tool kit and procedures to install thread inserts in the block, they are called a time-sert.
Sep 13, 2010 at 5:46 PM
