1998 Cadillac Deville electric window motor replacement
1998 CADILLAC DEVILLE
118,000 MILES • V8 • 2WD • AUTOMATIC
WABASHRAT
How do you get the to the drivers side window motor for replacement. I don't see any srews to even remove the outer panel. Any help would be appriciated
Feb 5, 2008 at 10:42 AM
ED ARMES
  • 129 POSTS
The electrical switches must be pryed out carefully with a screw driver and unplugged.
Remove door handle and door lock knob as required.
Use a putty knife to slide carefully between the metal and the panel. Pry gently out ward. The panels are attached with press in nylon fasteners around the perimeter of the door approximately 6 to 8 inches apart. when all fasteners are popped loose, lift panel up and off door.
If this helps, give us some fe$$edback if possible.
Mar 8, 2008 at 4:51 PM
BUZZSAW
  • 1,198 POSTS
[quote:e1548d08b3="wabashrat"]Other Category problem
1998 Cadillac Deville V8 Two Wheel Drive Automatic 118000 miles
How do you get the to the drivers side window motor for replacement. I don't see any srews to even remove the outer panel. Any help would be appriciated[/quote:e1548d08b3]
I would say its the switch, In my 5 years as a tech I vary rarely replaced window motors, you need to hit the switch hard with your finger, while looking at the dome lite, watch for it to dim. if it doesnt its the switch
you will bust the door panel if you listen to ED, there are no plastic fasteners, its hooked in
Mar 10, 2008 at 6:36 AM
