1998 Cadillac Deville driver info center
130,000 MILES • V8 • 2WD • AUTOMATIC
LOGANZZZ
Thanks for the answer of my first question- I will make a donation on payday-My instrument panel ,(cluster)- is not working- Everything else is working- I checked the 10a fuse in the trunk(RLY IGN 1)- which controls cluster- and that is working- the far right fuse in the trunk that is designated cluster-is a 20a- that is in properly also.
So my avg/inst mileage is working- my ac digital is working- but the main screen- driver info center- is not displaying? Is there some type of cluster bulb or other area,(fuse box under hood- etc) that needs to be checked or replaced. short?- all the other lights are working - less my DIC- any suggestions?
Driss RN Transplant Nurse
Oct 15, 2010 at 10:38 PM
FACTORYJACK
  • 4,159 POSTS
It is a vacuum flourescent type illumination. Since some info is displayed, and there is actual data(climate/trip computer) it indicates there is power and communications to the system. It sounds most likely to be a fault within the cluster. If you replace it, it will need programmed with the theft information(theft relearn), as that vehicle stores the theft password in the IPC.
Oct 16, 2010 at 7:19 AM
