1998 Cadillac Deville Changing wheel bearings
150,000 MILES • V8 • 2WD • AUTOMATIC
FIRLEY
We are attempting to change the front wheel bearings. Any tricks ???
How to get the old bearing assembly off.
Mar 13, 2010 at 7:09 AM
FACTORYJACK
  • 4,159 POSTS
Loosen the big axle nut first to be able to push the cv joint in for access. Be careful on the 13mm hub bolts, they are thin and somewhat soft. It can be made a little easier by heating the bolts at the threaded(hub) end, they have threadlocker on them and heat softens it.
Mar 13, 2010 at 5:27 PM
