1998 Cadillac Deville cadillac idling and brakeing problem
156,000 MILES • V8 • FWD • AUTOMATIC
GOTRIBE95
I have a 1998 cadillac sedan deville that is idling high and low sporadically. It also feel;s like there is air in the brake lines or that maybe even the power brakes have failed at start up. Both of these problems happened at the exact same time. The RPM's are running high and low even in park. If I try and put the car in gear it takes off at a high rate of speed. What are your thoughts. I really appreciate your time. Thank you.
Feb 27, 2008 at 11:58 AM
BUZZSAW
  • 1,198 POSTS
[quote:3e6c69bd4e="gotribe95"]Engine Performance problem
1998 Cadillac Deville V8 Front Wheel Drive Automatic 156000 miles
I have a 1998 cadillac sedan deville that is idling high and low sporadically. It also feel;s like there is air in the brake lines or that maybe even the power brakes have failed at start up. Both of these problems happened at the exact same time. The RPM's are running high and low even in park. If I try and put the car in gear it takes off at a high rate of speed. What are your thoughts. I really appreciate your time. Thank you.[/quote:3e6c69bd4e]
sounds like a vaccum leak in the brake booster line. are the brakes hard as a rock to stop or spungey?
clean the throttle plates with carb cleaner, and an old tooth brush
Mar 5, 2008 at 1:26 AM
