1998 Cadillac Deville ABS
96,700 MILES • V8 • 2WD • AUTOMATIC
DT2HORAN
ABS & Traction control lights stay on. No problem braking or driving the car. Checked fuses & they are good. Brake fluid level good.
If I get computer diagnosis & control module need to be replaced...could I do this myself. I have a Haynes manual & it does not tell how to replace ABS components. Do you know of a manual that has ABS replacement in it? Thanks
Dec 29, 2007 at 8:34 AM
BUZZSAW
  • 1,198 POSTS
[quote:0364c201ec="dt2horan"]Brakes problem
1998 Cadillac Deville V8 Two Wheel Drive Automatic 96700 miles
If I get computer diagnosis & control module need to be replaced...could I do this myself. I have a Haynes manual & it does not tell how to replace ABS components. Do you know of a manual that has ABS replacement in it? Thanks[/quote:0364c201ec]
pull the codes, off and warmer on heater controls, its probally a wheel sensor, have you had rear brakes put on sence the lite?
Jan 5, 2008 at 7:18 AM
