1997 Cadillac Deville Stiff shift handle
125,000 MILES • V8 • 2WD • AUTOMATIC
NG25441705
Trans seems to work ok, but handle is increasingly hard to push, in every direction.
Dec 17, 2009 at 3:46 AM
FACTORYJACK
  • 4,159 POSTS
Disconnect the cable at the trans end, and see if it frees up. Has there been any trans service requiring the upper valve body or side removed prior to this?
Dec 17, 2009 at 1:50 PM
NG25441705
No repairs or service to trans.
I don't plan to get under it myself, just want an outline of probabilities. thanks
Dec 18, 2009 at 1:55 AM
FACTORYJACK
  • 4,159 POSTS
Probabilities include something in the column(it is not a concours?), a cable that is bent/broken or fraying inside the casing, or something binding the manual shaft/valve in the trans. You do not need to get under it to disconnect the cable at the trans. The cable comes across the engine, is retained in a bracket at the trans, and the level can be seen from the engine compartment. This can eliminate the most expensive part(trans).
Dec 18, 2009 at 3:35 PM
