1997 Cadillac Deville rear air shock absorbers and upper &a
79,000 MILES • V8 • 2WD • AUTOMATIC
PATC
Have been told that my shocks are leaking and the upper and lower bushings have play in them. Servicer says all need tobe replaced. What are the consequences of doing nothing about this now?
Sep 11, 2009 at 7:17 AM
FACTORYJACK
  • 4,159 POSTS
Is it in relation to what the vehicle was brought in for service, for? Or is it service recommendations after inspection? I am not certain what is meant by upper and lower bushings, is it on the rear suspension.
Sep 11, 2009 at 3:51 PM
PATC
Brought in for inspection. Yes, it's rear suspension area. Another term for the bushings, used by a different servicer was "bearings" at either end of the struts.
Sep 12, 2009 at 5:32 AM
FACTORYJACK
  • 4,159 POSTS
You would have no 'bearings' on the rear shocks, since they remain stationary. On the other hand, front struts have an upper strut bearing that allows them smooth rotation during steering. Bushings on the rear, would relate to upper and lower knuckle bushings, that is the only thing I can think they would have noticed having play. Shocks leaking is not uncommon, and you may or may not notice a difference after replacement. The loss of fluid in the shock, is replaced by air, and can create a void in absorbtion. If you are not experiencing tire wear, or noise, such as knocking or clunk, you could probably get by without replacement for now. Leaking shocks will only continue to leak, and worn bushings will continue to wear. At some time, you may get a second opinion, and see if it concurs. By this, I would not go to a shop and say that you were told your shocks were leaking and bushings have play. Have an inspection, or routine service, and see if the same recommendations are made. This would validate if a concern really exists.
Sep 12, 2009 at 5:45 AM
