1997 Cadillac Deville NO INJECTOR PULSE
97,000 MILES • V8 • FWD • AUTOMATIC
MRDEVILLE1
  • 6 POSTS
I HAVE NO INJECTOR PULSE . HAYNES REPAIR MANUAL SAID THE PCM CONTROLS INJ PULSE BUT I CAN T FIND THE LOCATION OF THE PCM. THE MANUAL HAS THE LOCAL FOR 2000 AND LATER I LOOKED UNDER DASH BOTH SIDES AND UNDER HOOD FRONT DRIVERS SIDE DID NOT SEE ANY THING... IS THE PCM MY PROBLEM AND WERE IS IT .......THANK U CARL
Feb 15, 2009 at 9:21 AM
  • 75,988 POSTS
Check the injector fuses 10amp if okay turn ignition On and check for power at the pink wire of the injector harness connector-power here-You have a problem with the computer ground drivers circuit.
Feb 15, 2009 at 9:35 AM
MRDEVILLE1
  • 6 POSTS
[quote:28c501b032="rasmataz"]Check the injector fuses 10amp if okay turn ignition On and check for power at the pink wire of the injector harness connector-power here-You have a problem with the computer ground drivers circuit.[/quote:28c501b032]
fuses good there were two.. have power to pink wire in harness... whats next...
Feb 15, 2009 at 10:33 AM
  • 75,988 POSTS
Replace the computer it has a bad ground drivers
Feb 15, 2009 at 11:50 AM
MRDEVILLE1
  • 6 POSTS
[quote:bb900cae38="rasmataz"]Replace the computer it has a bad ground drivers[/quote:bb900cae38] were can i find the computer i looked under dish didn t see it looked umder hood didn t see it... whats it location....1997 cad. dvville 4.6 v8 northstar. try to be exceted... thank u... p s i have two parts cars 97 & 98 both devilles can i use a computer from one of them......
Feb 15, 2009 at 1:51 PM
  • 75,988 POSTS
The computer is located left front of engine compartment under aircleaner housing
Feb 15, 2009 at 2:09 PM
MRDEVILLE1
  • 6 POSTS
i took a computer from another 97 deville i have, i changed the chip from one to the other. still wont start.. both computers. have same part #s. what else should i try.... thank u carl
Feb 23, 2009 at 1:28 PM
  • 75,988 POSTS
Try checking the camshaft position sensor some computers use its signal to synchronize the injectors
Feb 23, 2009 at 1:41 PM
