1997 Cadillac Deville no fuel delivery
83,000 MILES • V8 • FWD • AUTOMATIC
RRRRICK88
had a service fuel system warning light ......2 weeks later no start.........new fuel pump relay,pressure hold diaphram on fuel rail .... cleaned all connections, looked for shorts .....no luck......sat over winter in garage .........charged dead battery , starts right up runs great after warm up stuck lifter noise went away........no codes, no lights ....... perfect idle / to 3200 rpm smooth and quiet.....shut key off 5 mins later fading fuel pressure no start service fuel system warning light ? faulty fuel pump intermitent ?
May 3, 2010 at 11:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
We apologize for the slower than normal response.
From what you have stated, we believe you may have a failing fuel pressure regulator. Low fuel pressure during initial fuel system priming may be due to fuel pressure regulator leaking internally. Check the fuel pressure regulator vacuum line for presence of fuel. If OK, check fuel pressure. Record Key On Engine Off pressure. Residual fuel pressure should not drop more than 5 PSI in 10 minutes. If it does, repeat test. Restrict return line after pump shuts off. If fuel pressure does not drop after restricting, suspect fuel pressure regulator leaking internally.
May 5, 2010 at 11:28 AM
