This is my second attempt to get an answer, my caddy will show the flashing red light, low oil pressure stop engine????
Jan 1, 2010 at 9:11 AM
FACTORYJACK
✓Experienced Mechanic
Do you have accompanying engine noise of any kind? You could have a bad oil pressure sensor. If you don't have any noise, specifically top end, then I would suggest replacing the sensor. If it would make you more at ease, have the pressure tested.
