1997 Cadillac Deville Leaking
145,500 MILES • V8 • 2WD • AUTOMATIC
SKYFX1
I replaced my water pump and radiator and it is still leaking and overheating what else could it be I don't see it leaking any where and the Oil is still good heater core was replaced last year
Jul 6, 2010 at 11:27 AM
FACTORYJACK
  • 4,159 POSTS
By still leaking, but not seeing it leaking anywhere, you are losing coolant with no external leaks. If you have this in conjunction with overheating, I would recommend the cooling system be tested for the presence of combustion gases. This would indicate an internal leak, head bolt thread failure most probable. 97 was a common year for this type of fault.
Jul 7, 2010 at 3:29 AM
