1997 Cadillac Deville Leaking
SKYFX1
  • 1997 CADILLAC DEVILLE
  • V8
  • 145,500 MILES
I replaced my water pump and radiator and it is still leaking and overheating what else could it be I don't see it leaking any where and the Oil is still good heater core was replaced last year
Tuesday, July 6th, 2010 AT 6:27 PM
FACTORYJACK
  • 4,159 POSTS
By still leaking, but not seeing it leaking anywhere, you are losing coolant with no external leaks. If you have this in conjunction with overheating, I would recommend the cooling system be tested for the presence of combustion gases. This would indicate an internal leak, head bolt thread failure most probable. 97 was a common year for this type of fault.
Wednesday, July 7th, 2010 AT 10:29 AM
