1997 Cadillac Deville antifreeze leaking
194,000 MILES • V8 • 2WD • AUTOMATIC
THREEWILDKIDS28
my cadillac started leaking really bad. when i drive for awhile and stop and park it or let it idle in one spot i notice the antifrezze just starts pouring out in the front and if your sitting in the car its the right side up front under the radaitor in the corner. what could this be.
May 13, 2009 at 12:55 AM
MMPRINCE4000
  • 8,548 POSTS
Have a compression test performed to rule out a head gasket problem, then pressure test the cooling system, could be a hose or radiator/connection to radiator.
You want to get this fixed ASAP, do not overheat this engine.
Aug 18, 2019 at 3:05 AM
