1997 Cadillac Deville
EDGREENE
  • 5 POSTS
Engine Performance problem
1997 Cadillac Deville V8 Two Wheel Drive Automatic
engine will idel most the time at 625 to 750 rpm without stalling. When put in drive with brake on will stall 75% of the time within 5 min some times just a near stall. No pcm codes. iac,tp,egr,emc,map.maf have all been repalce. pcv has been cleaned,throtle bode has been cleaned. 2 of 4 o2 sencers replaced, vacume holdes stedy at about 15,fuel presure holdes stedy at 40 lbs. Dos not stall well driving.Getting worse afrad to go on planed trip. Whats wrong? Also if pcm is replaced dose it have to be flashed after instalation or can it be done at a deler then instaled?
Apr 30, 2008 at 12:51 AM
  • 55,743 POSTS
When a egr valve fails it will create an internal vacuum leak causing the engine to stall. Remove your egr valve to make sure the valve is closed and get back too me.
Apr 30, 2008 at 9:28 AM
EDGREENE
  • 5 POSTS
[quote:4d727334e5="2CarPro Ken"]When a egr valve fails it will create an internal vacuum leak causing the engine to stall. Remove your egr valve to make sure the valve is closed and get back too me.[/quote:4d727334e5]the egr valve has already been replaced. I did today replace the crankshaft sensors and test drove without any stalling it apears at this time that was the problem. You didn;t answer weath or not a pcm has to be in the car when it is flashed or not. Thanks ed
Apr 30, 2008 at 3:16 PM
BUZZSAW
  • 1,198 POSTS
[quote:653d097655="edgreene"][quote:653d097655="2CarPro Ken"]When a egr valve fails it will create an internal vacuum leak causing the engine to stall. Remove your egr valve to make sure the valve is closed and get back too me.[/quote:653d097655]the egr valve has already been replaced. I did today replace the crankshaft sensors and test drove without any stalling it apears at this time that was the problem. You didn;t answer weath or not a pcm has to be in the car when it is flashed or not. Thanks ed[/quote:653d097655]
yes it has to be flashed at the dealer and so does the crank sensors a relearn has to be done
Apr 30, 2008 at 3:24 PM
EDGREENE
  • 5 POSTS
[quote:e84452b6d0="Buzzsaw"][quote:e84452b6d0="edgreene"][quote:e84452b6d0="2CarPro Ken"]When a egr valve fails it will create an internal vacuum leak causing the engine to stall. Remove your egr valve to make sure the valve is closed and get back too me.[/quote:e84452b6d0]the egr valve has already been replaced. I did today replace the crankshaft sensors and test drove without any stalling it apears at this time that was the problem. You didn;t answer weath or not a pcm has to be in the car when it is flashed or not. Thanks ed[/quote:e84452b6d0]
yes it has to be flashed at the dealer and so does the crank sensors a relearn has to be done[/quote:e84452b6d0]buzzsaw I put the crankshaft sensors in and just drove off everything seems to be fine no dealer relearn.
Apr 30, 2008 at 3:39 PM
BUZZSAW
  • 1,198 POSTS
[quote:d02b784b51="edgreene"][quote:d02b784b51="Buzzsaw"][quote:d02b784b51="edgreene"][quote:d02b784b51="2CarPro Ken"]When a egr valve fails it will create an internal vacuum leak causing the engine to stall. Remove your egr valve to make sure the valve is closed and get back too me.[/quote:d02b784b51]the egr valve has already been replaced. I did today replace the crankshaft sensors and test drove without any stalling it apears at this time that was the problem. You didn;t answer weath or not a pcm has to be in the car when it is flashed or not. Thanks ed[/quote:d02b784b51]
yes it has to be flashed at the dealer and so does the crank sensors a relearn has to be done[/quote:d02b784b51]buzzsaw I put the crankshaft sensors in and just drove off everything seems to be fine no dealer relearn.[/quote:d02b784b51]
you will get a ck engine light on, where did you have your codes read at?
Apr 30, 2008 at 3:41 PM
EDGREENE
  • 5 POSTS
[quote:76b458f6de="Buzzsaw"][quote:76b458f6de="edgreene"][quote:76b458f6de="Buzzsaw"][quote:76b458f6de="edgreene"][quote:76b458f6de="2CarPro Ken"]When a egr valve fails it will create an internal vacuum leak causing the engine to stall. Remove your egr valve to make sure the valve is closed and get back too me.[/quote:76b458f6de]the egr valve has already been replaced. I did today replace the crankshaft sensors and test drove without any stalling it apears at this time that was the problem. You didn;t answer weath or not a pcm has to be in the car when it is flashed or not. Thanks ed[/quote:76b458f6de]
yes it has to be flashed at the dealer and so does the crank sensors a relearn has to be done[/quote:76b458f6de]buzzsaw I put the crankshaft sensors in and just drove off everything seems to be fine no dealer relearn.[/quote:76b458f6de]
you will get a ck engine light on, where did you have your codes read at?[/quote:76b458f6de]
I have a code reader. No mil light since replacing ck sensors so haven't scaned for codes. Also it was from reading one of your repliels to others that made me try the ck sensors. thanks for the info Ed
Apr 30, 2008 at 4:12 PM
BUZZSAW
  • 1,198 POSTS
[quote:08ad29c702="ed greene"][quote:08ad29c702="Buzzsaw"][quote:08ad29c702="ed greene"][quote:08ad29c702="Buzzsaw"][quote:08ad29c702="ed greene"][quote:08ad29c702="2CarPro Ken"]When a egr valve fails it will create an internal vacuum leak causing the engine to stall. Remove your egr valve to make sure the valve is closed and get back too me.[/quote:08ad29c702]the egr valve has already been replaced. I did today replace the crankshaft sensors and test drove without any stalling it appears at this time that was the problem. You didn;t answer whether or not a pcm has to be in the car when it is flashed or not. Thanks ed[/quote:08ad29c702]
yes it has to be flashed at the dealer and so does the crank sensors a relearn has to be done[/quote:08ad29c702]buzzsaw I put the crankshaft sensors in and just drove off everything seems to be fine no dealer relearn.[/quote:08ad29c702]
you will get a ck engine light on, where did you have your codes read at?[/quote:08ad29c702]
I have a code reader. No mil light since replacing ck sensors so haven't scanned for codes. Also it was from reading one of your replies to others that made me try the ck sensors. thanks for the info Ed[/quote:08ad29c702]
you dont need a scanner for a caddie, it has self diagnostics, push off and warmer at the same time on your heater controls, with the key in the on position, this will allow you to read codes. look in the IP message center for the codes. this will give you all codes for the engine, suspension, and body codes
May 1, 2008 at 3:27 AM
EDGREENE
  • 5 POSTS
[quote:bb546742c1="Buzzsaw"][quote:bb546742c1="ed greene"][quote:bb546742c1="Buzzsaw"][quote:bb546742c1="ed greene"][quote:bb546742c1="Buzzsaw"][quote:bb546742c1="ed greene"][quote:bb546742c1="2CarPro Ken"]When a egr valve fails it will create an internal vacuum leak causing the engine to stall. Remove your egr valve to make sure the valve is closed and get back too me.[/quote:bb546742c1]the egr valve has already been replaced. I did today replace the crankshaft sensors and test drove without any stalling it appears at this time that was the problem. You didn;t answer whether or not a pcm has to be in the car when it is flashed or not. Thanks ed[/quote:bb546742c1]
yes it has to be flashed at the dealer and so does the crank sensors a relearn has to be done[/quote:bb546742c1]buzzsaw I put the crankshaft sensors in and just drove off everything seems to be fine no dealer relearn.[/quote:bb546742c1]
you will get a ck engine light on, where did you have your codes read at?[/quote:bb546742c1]
I have a code reader. No mil light since replacing ck sensors so haven't scanned for codes. Also it was from reading one of your replies to others that made me try the ck sensors. thanks for the info Ed[/quote:bb546742c1]
you dont need a scanner for a caddie, it has self diagnostics, push off and warmer at the same time on your heater controls, with the key in the on position, this will allow you to read codes. look in the IP message center for the codes. this will give you all codes for the engine, suspension, and body codes[/quote:bb546742c1]
I know about the caddy self reader. Not nessary to read codes at this time. As I stated the car is running fine no mil light. We have driven the first 1000 miles of a 8500 mile trip.
May 3, 2008 at 2:05 PM
