1996 Cadillac Deville window
100,000 MILES • V8 • FWD • AUTOMATIC
PAT1349
power window my window wont roll up its not my battery could it be relays if so where are my relays located and witch relay is it? i checked my fuses but all them look good but i dont know because i dont got the fuse box diagram
Dec 28, 2007 at 12:42 PM
LUCKY956
it could be your motor for the windows it probably burned out. you need to remove the door panel and check the motor and the teeth. the same thing happen to me i had to replace the whole motor its not expencive.
Jan 4, 2008 at 5:19 AM
BUZZSAW
  • 1,198 POSTS
[quote:ad2e4159c7="pat1349"]Electrical problem
1996 Cadillac Deville V8 Front Wheel Drive Automatic 100000 miles
power window my window wont roll up its not my battery could it be relays if so where are my relays located and witch relay is it? i checked my fuses but all them look good but i dont know because i dont got the fuse box diagram[/quote:ad2e4159c7]
use you finger and hit the window switch hard a few times, bet it s the switch
Jan 5, 2008 at 6:39 AM
