1996 Cadillac Deville Six way split power seats
80,000 MILES • V8 • FWD • AUTOMATIC
1955SKH
  • 6 POSTS
The drivers side seat will move in all directions except back and forth. Where should I start looking, the switch or motor? Thanks in advance for your help.
Aug 29, 2009 at 7:50 AM
FACTORYJACK
  • 4,159 POSTS
If you know which motor it is, check power and ground at the connector when the switch is cycled. The easiest method would be a test light, and it should light in both directions, it just reverses polarity. If it does light in both directions, the motor is failed. I don't believe the motors are available seperately.
Aug 30, 2009 at 4:12 AM
1955SKH
  • 6 POSTS
thanks for your reply. I will give it a try.
Aug 30, 2009 at 6:37 AM
