The blower is at high speed al the time, no heat or air, can not adjust blower speed or temperature. It is a auto system
Wednesday, March 19th, 2008 AT 11:52 PM
BUZZSAW
MECHANIC
Have you tried scanning your codes, push off and warmer at the same time, with key in the on position, on your heater controls. Look at the IP for the codes. If you cant pull codes you need to replace the heater head
