Engine problem
1996 Cadillac Deville V8 Front Wheel Drive Automatic
how do you do a leak down test pulled plugs ,put air in cyl. hear air leaking into plenum and escaping from other plug holes engine runs not out of time . at idle temp stays at 196* but in drive. foot on brake ,part. throttle temp goes to 200* plus and cooling system pressure goes to 30 psi+ is this a blown headgasket or a crackedhead ? thanks lrac55
Jan 7, 2008 at 10:13 AM
