1996 Cadillac Deville Ignition Switch
AMANDAMETCALF
Electrical problem
1996 Cadillac Deville V8 Two Wheel Drive Automatic 155K miles
My car says starting diabled due to security theft.... after numerous times of trying to start it. Ive tried unhooking the battery and all that fancy stuff with the door locks and so on. Ive been told this means either the keyes bad or the ignition switch or both. Does anyone now how to install an ignition switch in th POC? Plz help! Thanks
Mar 13, 2010 at 2:13 PM
FACTORYJACK
  • 4,159 POSTS
It is not the switch, it is the ignition lock cylinder in the steering column. It requires removal of the airbag, steering wheel, coil, lock plate, and turn signal switch.
Mar 13, 2010 at 5:22 PM
