1996 Cadillac Deville Fault codes PO716 & PO717
65,636 MILES • V8 • FWD • AUTOMATIC
COVERBEY
Smog test station reported the two fault codes listed and service engine liight resulting in a functional fail (emissions all ok) What can be done to erase computer memory long enough to pass the smog test? Thanks
Oct 14, 2009 at 10:20 AM
MATHIASO
  • 1,209 POSTS
it seem like you are not intersted in fixing the codes, you may need MIL Eliminator to pass the smog test .
https://www.2carpros.com/trouble_codes/obd2
Oct 14, 2009 at 11:41 AM
COVERBEY
Generally available at auto parts stores???
Oct 14, 2009 at 11:55 AM
SERVICE WRITER
  • 9,123 POSTS
What are the code numbers?
What state are you in and what is the criteria in y0our state to pass/fail emission tests?
Oct 14, 2009 at 12:15 PM
COVERBEY
PO716 and 717. In California.
The smog technician wrote on the order "MIL is on (2) fault codes found-see VIR. Service engine soon light is on."
The car passed the visual inspection and emmissions test but failed the functional check.
They gave me the impression, without saying outright, something could be done to "wipe out the computer memory" operate the car through a few drive cycles to reboot the computer and retake the test.
Hope this helps. Thanks
Oct 15, 2009 at 4:28 AM
SERVICE WRITER
  • 9,123 POSTS
Both codes are related to the coolant temperature sensor....probably a bad sensor.
Oct 15, 2009 at 5:00 AM
CADILLACGURU
P0716 Input Speed Sensor CKT Range/Performance
P0717 Input Speed Sensor Circuit No Signal
Nov 10, 2009 at 4:24 PM
