1996 Cadillac Deville engine mis-fire?
154,000 MILES • V8 • 2WD • AUTOMATIC
CLOS
things i should mention:
1st time Caddy owner of a 96 deville with 150k miles. Have owned it for about a month. So far, it has shown consistent rpms both idle and running. Coolant temp stays between 206 and 212. Havent had any problems until today. After washing my engine with a common degreaser and a gentle spray down with a pressure washer (making sure not to touch the coil system) i started the car and it felt like it was choking. after running a diagnostic, the computer read "troubleshooting PO300". I noticed white fumes from the engine. I know this could be leftover degreaser burning off but i also feel that one or more cylinders may be mis-firing. How can i troublesoot this without paying hundreds of dollars or taking it to a mechanic? please help. i spent all my money to buy the car and am broke until next payday.
Jun 5, 2010 at 2:44 PM
  • 75,988 POSTS
P0300 Random misfire is normally caused by vacuum leaks and bad fuel other causes below
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
8.EGR valve that is leaking.
9.Oxygen sensors.
Jun 5, 2010 at 2:53 PM
