1996 Cadillac Deville cooling fan
187,714 MILES • V8 • 2WD • AUTOMATIC
G2SHANKS
At what temp should the cooling fans come on? They are not coming on at anywhere from 197-213, and where are the fuses or relays for the cooling fans located?
May 25, 2010 at 1:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the PCM will turn on the cooling fan(s) at low speed when the coolant temp. exceeds 223F
Jun 1, 2020 at 7:39 AM
CARRO
IS your car overheating? How high has the temperature risen and you notice that the fan is not on?
