1996 Cadillac Deville compressor
110,000 MILES • V8 • FWD • AUTOMATIC
DWJOHNSON
  • 5 POSTS
My mother-in-law's compressor's clutch will not engage. Until I get it to my house I cannot reach the electrical plug to the clutch to see if it is getting voltage nor can I reach the clutch to see if the compressor is frozen. The system pressure is good and jumping the low pressure switch causes no change. The dash readout says the ac pressure is low and the compresser is not on. The fuse is good. I set the controls to call for cooling. I thought about swapping the fuel pump relay with the compressor relay but I need the car at my house in case anything kills the relays.
Any suggestions?
Mar 3, 2008 at 3:42 AM
BUZZSAW
  • 1,198 POSTS
[quote:ee010120fb="dwjohnson"]Air Conditioning problem
1996 Cadillac Deville V8 Front Wheel Drive Automatic 110000 miles
Any suggestions?[/quote:ee010120fb]
you have to erase the codes to get the ac to work, if freon is low it still wont work
Mar 5, 2008 at 12:35 AM
